Interior light (Front) Help..
Does anyone know how to remove the panel to get at the bulbs in a 2000 Millenia?
I don't want to break anything.. Thanks.. |
RE: Interior light (Front) Help..
Which bulbs are you trying to replace?
on our 99's, there are 2 screws that hold the panel on. both are right next to the steering column. one is hidden by the rheostat for the dash lites, the other is under a matching plate on the right side. you remove those 2 screws, then the dash panel will GENTLY pry off. if you open the glovebox, you can start there, and work your way around. it's actually very easy, just a bit scary.
It's the Map lights -center 8w
Thanks for the help |
| All times are GMT -5. The time now is 09:43 AM. |
