Interior light (Front) Help..
on our 99's, there are 2 screws that hold the panel on. both are right next to the steering column. one is hidden by the rheostat for the dash lites, the other is under a matching plate on the right side. you remove those 2 screws, then the dash panel will GENTLY pry off. if you open the glovebox, you can start there, and work your way around. it's actually very easy, just a bit scary.
trace66usa
Jul 3, 2008 04:08 PM
