Ignition Coil location on 95 Millenia???
having trouble getting car to start..changed out the spark plugs, wires and dist. cap and rotor button...but now i'm not getting any fire from the plugs...
any idea what it could be?..heard either the ignition coil or Crank Sensor...where is the ignition coil located at on a 1995 Mill?
The Coil is built into the Distributor, you can't replace just the coil. Have to replace the whole shebang. If you haven’t bought a replacement yet I would suggest checking out these guys http://stores.ebay.com/DISTRIBUTOR-KING. They claimed to have re-engineered the distributor to handle more heat etc. I bought one from them for my milly and it is quite a bit heftier than the OE one. The cost didn't seem too different from a rebuilt either. I stuck it in and it fired right up. No problems so far.
littleman626
Jul 27, 2011 02:42 PM
95, button, changing, coil, coils, distributor, firing, ignition, installation, located, location, mazda, millenia, replacement, rotor
