Help No Spark
ok so go to turn on my car and it just cranks , i check the wires and im not gettin any spark , i check all my fuses and relays , i changed the rotor , i changed the cps , im about to changed the distributor but wanted any advice first on how to diagnos the problem , and do distributors go bad on these things often? i heard they do
Checking your distributor would be the right thing to do. The ignitor often goes bad, which is inside the distributor. I recently experienced poor performance from the ignitor and the coil. Replaced both and the car runs fine. No spark at all could be caused by ignitor and/or coil.
yea thats what i was thinking , and the coil is inside the distributor and so is the ignition module , so ill let u know if it was that , thanx for you help
| All times are GMT -5. The time now is 05:13 AM. |
