Help!! Millenia 97 TCS & ABS lights turned on
Hi, I just changed the brake pads on the 4 wheels and when I started the engine the warning lights for ABS & TCS on the dash turned on. Is there any way to reset them? What can I do, I just disconnect the battery for a few minutes, but the lights still on. Thanks |
RE: Help!! Millenia 97 TCS & ABS lights turned on
the best way to turn them off is fix the problem. go back and check your work, you may have disconnected one of the abs sensors.
Also check to see that you didn't cut or split any wires by accident. Those lights are made not to clear unless the problem is resolved. There is no other way to turn them off.
