going crazy...8 CODES....YIKES
HEY GUYS...I HAVE MAJOR PROBLEMS..I HAVE HAD MY 99 MILLENIA FOR 2 YEARS AND HAVE NOT HAD A PROBLEM..RECENTLY WITHIN THE PAST 2 MONTHS I HAVE HAD AN ENGINE AND TRANNY FLUSH..THATS WHEN THE CEL CAME ON SHORTLY AFTER..I TOOK IT TO A MECHANIC AND WAS TOLD THAT A MISFIRE OCCURED...I TOOK IT TO A SECOND MECHANIC AND WAS TOLD THE EGR MALFUNCTIONED..AFTER THE 3RD MECHANIC SHOWED ME A LIST OF 8 CODES AND WAS NOT ABLE TO TELL ME WHAT THEY MEANT...SOMETHING SERIOUSLY WRONG HAS TO BE GOING ON WITH MY BABY...SHE DRIVES AWESOME BUT THE CEL BOTHERS ME...THE CODES ARE P11500, U01000, B0200, P0002,P0202,P1200, P000, AND FINALLY P0400....IS THERE ANYONE WHO CAN HELP ME UNDERSTAND WHAT THESE CODES MEAN ....IM STARTING TO WONDER IF I SHOULDHVE WENT WITH THE ACCORD INSTEAD!? THANKS IN ADVANCE
RE: going crazy...8 CODES....YIKES
List of code numbers is not valid. Per prior post this quote "P11500, U01000, B0200, P0002,P0202,P1200, P000, AND FINALLY P0400...." The only one that is listed in OE manual is the P0400 which is for the EGR flow malfunction. Try getting codes pulled again at perhaps an Autozone that will do OBDII scans for nothing. Do you have the 2.5 engine or 2.3 miller cycle?
sometime there are one 1 or 2 code that is the main problem but they lead to many other code like the problem you have now. buy scan tool from autozone or advance auto part to erase all code and drive it for couple day to see which code came up and verify and fix that code.
