Engine Mechanical problem/noise
2002 mazda millenia 2.5L got loud engine noise after start up or idling. the noise seems to almost dissapear or much less noticable when rpm above 2000rpm. The car has 135K mile. check engine light on with code 0300, 0350 and 0421. Changed all spark plugs afterward. The local mechanics told me the noise seems from inside timing belt cover, front of oil pan, rear upper valve train and water pump. I read one post said bad timing belt tensioner could cause engine noise/knocking. Timing belt never replaced on this car. Can anyone kindly provide the advice or similar experience? Many thanks.
Dude, do you have my car? LOL, mine's doing the SAME THING. And I was told by Mazda mechanic it's my timing belt. Which was my first instinct since the noise was right inside the belt cover. I have a 2001 2.5L and it looks like it's gonna be alot of fun putting the new one on.....not
Thanks, ZZ81. You are right. The hydraulic tensioner has fallen apart. The problem is solved. Re set the code. Hope it won't come back. I'll see.
So did you have to replace/fix the hydraulic tensioner or replace the timing belt? I'm trying to figure this out before I tear everything apart since you and I know what kinda hell that will be on this engine. Thanks.
Originally Posted by ZoomZoom81
(Post 112131)
was it a loud ticking noise that would sorta speed up with the rpms till it hit 2 grand? my 95 is doing the same thing im about to start taking the engine apart today
(Post 112131)
Originally Posted by derekoreo2004
(Post 112468)
Any body can tell what is the total cost to replace the timming belt?
