Codes on my 2000 Millenia S
Can anyone help me out??? I have a 2000 Mazda millenia S and it is running like s--t. It run's hot every once in a while and when I'm on the highway driving aprx. 65 miles per hour it is sputting/missing almost like gas isn't getting to the right place. I had radiator changed last week because they found a leak but it's still running hot, the only thing that has stopped since I changed the radiator is I'm no longer losing water. I went to a local shop and they ran codes and what showed is PO115, PO431, P1790...the guy told me he doen't work on this car so I'm stuck....don't know what to do. Any ideas what those codes mean? Also, TCS/OFF TCS/ON light comes on every blue moon.. Sometimes only TCS OFF, sometimes both, sometimes none...:(:(:(
0115=engine coolant temp circuit malfunction
0431=left bank warm up cat efficiency below threshold 1790=throttle position sensor open or short tcs off/tcs probably because of the 1790. engine sputtering and rough could be 0431, the cat is so clogged, it is not flowing, and you got tremendous back pressure, which also can make it run hot. and, after a while, it can make it stop running. forever |
I brought it to muffler shop to have the catalytic converter checked and the guy check it and also for an exhaust leak and told me the catalytic converter is clean, it looks new... i'm so confused... I'm a female going through a divorce so I'm lost, don't know much about vehicles. He didn't even charge me so I wouldn't think he would lie to me... What u think? Also, the guy I told you checked the codes yesteday said he didn't know much about this vehicle but he said he thinks it's a head gasket, what you think? My dad said he thought it would do it all the time...:eek::eek:
Originally Posted by lakynnb02
(Post 106121)
Thanks so much for your info. It's my fault because I didn't have the print out form the shop when I went to the muffler shop so I told them wrong only because the shop that ran the codes told me it was a exhaust leak or a faulty catalytic converter so I told them both those. now I know to go back and explain what you said!!!! Also, with the head gasket thing, don't you think some code would have showed that? And, doesn't water mix with the oil when that happens? I'm just trying to figure all this out because if its going to cost a fortune to fix, I'm done!!! It's a 2000 with 110,000 miles. It's not worth all that money!!!
(Post 106136)
