Cat codes and white smoke
hi babyhuey and keninn,
I just noticed white smoke like for 10 sec outta tail pipe. Does this solve the mystry of having P431 and P421 cat codes? I hope you remember my post about both cats goin bad ( which is quite rare). I think its this white smoke that is causing a problem(s) in catsand O2 sensors . I have browsed forum for the causes of white smoke and it looks like either supercharger is bad or oil seals have worn. Any advice would be helpful. Thanks in advance! |
RE: Cat codes and white smoke
are you sure it is smoke and not STEAM?
i dont think it's a solution. it could just be condensation that has settled in the exhaust after shutdown. white would be water/coolant. try go back and take a whiff of it, you can smell oil and coolant.
White smoke & sweet smell = coolant
Blue smoke = oil Black smoke = fuel |
I checked this morning again. Its not even 10 sec ( started the car and rantosee the tail) probably3 sec and its hard to tell dat smoke is blue or white because its not that dense . I smelled the smoke, nothing.May beI was just smelling air beacuseI hadnt had enough time to catch the smoke. I touched the tail pipe from inside to see any oil ( or carbon ) deposites..nothing. I don't know if something is wrong orI am just worrying about somethin which is not even there.
I do get cats code once in a while ( first P421 andifI dont clear itI would get P431 later; two codes). Had O2 sensors changed but problem didnt go away. I dont see any performance problem with the car and local mechanics also agreed that cats look fine and they are doing there job ( thats what their scanner showed everytime they checked it). I thought I nailed down the problem by identifying smoke..lol but looks like I didnt. |
