alternator/compressor belt
Hello, first post for me..i hate i coming in asking for info without contributing, but im in a jam. Can someone tell me where the tension pulley for the belt that goes around the alternator compressor. i've changed the alternator but cannot get the belt back on. thank you for taking time to read this and help me.
d.
d.
RE: alternator/compressor belt
That vertical screw is the adjustment screw. I will post a picture that should help as well. Loosen the 14mm nut in the center of the tensioner pulley ( A ) by a full turn or so. Now turn that vertical screw ( B ) counterclockwise. You should see the tensioner pulley coming upwards. Keep turning untill you are able to go ahead and install the belt. Reverse above steps to retension belt.
[IMG]local://upfiles/1377/3E95058DA9E24CA4955AC1F3AD717E4F.gif[/IMG]
Answe
d.
d.
sabanab35
07-18-2005 09:56 PM
