99 Millenia S - Bad catalytic converter...HELP!
I have a 99 Millenia S...my check engine light has been on for a little while now, and the code says that my cat is bad. I've been doing some research to replace it and it looks like I have a front and rear cat...how do I know which one is bad? or should i just get a whole new exhaust system?
Anyone have any suggestions on where to get an exhaust system with the cat? Thanks! :D |
RE: 99 Millenia S - Bad catalytic converter...HELP!
The code will tell you which it is.
Check engine light for cat converter
I'm in the same boat. Took my 99 milly to the dealership and they said my right front Cat Converter is going bad. Quoted me $1400 to fix. That's $1100 for the part and 3 for labor. That's ridiculous.
Originally Posted by Eaglesfan4lyfe
(Post 86369)
99 S with bad cat
Yep, I'm getting the bad cat code as well. And my mechanic, who I trust for his expertise, says "ignore it." Isn't there a work around, to kill this code?:)
Originally Posted by tgr
(Post 86529)
Keninn, you you say Tasca Mazda online huh? If the part's roughly $390, I'd much rather go that route. Is this something a regular mechanic can fix or do I need to take it to the dealership? Also, they said I need 2 bypass valves at around $200 a pop. Are these parts that need to be OEM or can I go anywhere for these??
I'm really at a crossroads right now with my milly. I've got 128K on it and still owe about $3000, these repairs are starting to add up(just had a belt tensioner and drive belt replaced-$700 parts & labor) I love the car and it drives nice when it works, but I can't keep pouring money into it. |
(Post 86795)
I'm really at a crossroads right now with my milly. I've got 128K on it and still owe about $3000, these repairs are starting to add up(just had a belt tensioner and drive belt replaced-$700 parts & labor) Plus the right front catalytic converter needs replacing. I really like the car and it drives nice when it works, but I can't keep pouring money into it. Would you hold onto the car or cut your losses, trade it in, and get something else??
(Post 87473)
