99 Mazda Millenia S
Hello i come here for help :)
My son just bought a used 99 Mazda Millenia S we went for a tune up and found out we hade to replace the # 3,4 Coil (but replaced all Spark plugs) once we fixed that issue we got another Code P1540 It has something to do with the traction control. i have been reading the forum and we saw a few options #1 pulling the TC from the computer of the car but it will also effect the ABS #2 Replace the ABV Solenoid Valve (Vent) i Also see that this issue can drive a person crazy Some one please help My Son |
I have same issue
Hi,
Did u get this issue resolved? How much are they charging you for an ABV vent solenoid. When i used the computer to show me the code it read P1526 which is the ABV vent solenoid. Let me know .. Thanks |
Originally Posted by djjohnnys
(Post 96467)
Hi,
I would have to disagree with you. I have two sources for P1526 being a vent solenoid.
1) http://members.cox.net/sciberpunkt/tech/obd/ P1525 - Lysholm air bypass valve (ABV) vacuum solenoid circuit malfunction P1526 - Lysholm air bypass valve (ABV) vent solenoid circuit malfunction 2) I used the computer myself and it said "ABV vent Solenoid P1526" at a fast speed and hot day. Anyways, Is it easy to replace both? and do I have to change anything else like hoese and tees? Thanks |
(Post 96578)
1) http://members.cox.net/sciberpunkt/tech/obd/ P1525 - Lysholm air bypass valve (ABV) vacuum solenoid circuit malfunction P1526 - Lysholm air bypass valve (ABV) vent solenoid circuit malfunction 2) I used the computer myself and it said "ABV vent Solenoid P1526" at a fast speed and hot day. Anyways, Is it easy to replace both? and do I have to change anything else like hoese and tees? Thanks UPDATE: after asking other members to look, my fsm is misprinted. checking the diagnosis section confirms that 1525 is the vacuum, etc. however, i ALWAYS replace both vacuum and vent, since i ohm them to check, and they are always both bad. also, they may ohm ok when cool, but when hot they fail. |
True. BTW a mazda dealership told me that it takes an hour to change the vent solenoid and it will cost me 99 bux for labor. Part costs about 75. So looking at almost 200 with taxes. And if I change vacumm as well it will go toward 300 bux. Pretty costly.
My question to you: Is it easy to replace myself (Like a do it your self) ? And if so, do you happen to know where I can find the scematics online? Thanks for your help! Really appreciate it! |
(Post 96639)
O sweet..ye my neighbour was some sort of car mechanic beofre and offered to help me out but was asking me to find out some details first....
So the solenoids are under the top part of the engine (which includes ABV and CAC bypass actuators) right? Is that top part easy to slip off with the 10/12 mm wrench? After I break off the solenoid, I connect the new one and Do I need to solder the vacumm lines back on? |
(Post 96752)
So the solenoids are under the top part of the engine (which includes ABV and CAC bypass actuators) right? correct Is that top part easy to slip off with the 10/12 mm wrench? you will at least need 10 and 12 mm sockets, and possibly a 10mm box wrench. After I break off the solenoid, I connect the new one and Do I need to solder the vacumm lines back on? the connections/wiring harness and the vacuum lines have all taken a "set" from age and heat cycles. some are brittle, and may break. you should be prepared to replace some of the vacuum line. there is approx 21 feet of vacuum line on this motor |
Originally Posted by keninn
(Post 96584)
disagree all you want. i am looking at the mazda FACTORY SERVICE MANUAL, for 99 millenia, which we have 2 of. section 01-01B-7, 'P1525 ABV solenoid valve(vent) open or short'. P1526 ABV solenoid valve(vacuum) open or short. so, the mazda fsm(9999-95-058B-99) which i bought in 99 when we bought our first millenia is wrong, and all your sources are not? i dont think so. but hey, it's your car, so whatever. both of ours run fine, and i have already dealt with 1525/26/40 problems.
UPDATE: after asking other members to look, my fsm is misprinted. checking the diagnosis section confirms that 1525 is the vacuum, etc. however, i ALWAYS replace both vacuum and vent, since i ohm them to check, and they are always both bad. also, they may ohm ok when cool, but when hot they fail. Yes, your book was wrong, but that doesn't make you correct. |
