7 codes on 95s tranny help!!!!!!!!!!!!
i have a mazda millenia s 95 126000, i got the car no codes and ran it for about 2 weeks all
good no code at all then one day the hold light started to flash and the
tcs came on to and the check engine light came on . it made the car drive like
**** i would have to trun the car off b/c it got that bad
it feels like the car is always on 3rd gear from start and even on the high way so i toke it
to autozone and 7 codes came up p1743,p0745,p1000,p1601,p0750,p1770,p0710
what i dont understand is i was driving the car just fine
i have the repair manuel and i dont know if its a bad tranny or sould i replace all those sensors or what?
can someone help me mabe i can fix it myself
i got it down to 4 codes by getting a new tranny compouter i olny have p0745, p1743,p1770,p10000 and 3 of this is trany code i need a pressure control solenoid ,lock-up solenoid, overrunning clutch solenoi, doses any one know if they go or is the tranny not good anymore help any one thank u
Check the posting titled "P0725" it discusses a lot about this, I am having the same problems. I have had it at one Mazda dealer and was told all vacuum lines were OK and it was a bad Throttle Body. I haven't done anything yet as it looks like many things are suspicious, yet no cure has been found yet (at least by me). Let me know if you find some good information or get your problem solved; I'll do the same.
b6t323
Mar 28, 2013 12:10 PM
