2000 Millenia shifter noise
Car starts fine, when you press the brake pedal in while in park you can hear what sounds like a solinoid right under the shifter make noise, when shifter release button is pressed you can hear a similar noise right behind the ignition switch. When shifted to any gear no noise is made upon release of brake, however when going back to park noise is made again when releasing brake while in park. any suggestions on what to look for and how to get the trim off around shifter to examine parts?
Originally Posted by sxrxndnb
(Post 88060)
