1999 mazda millenia S TCS & TCS OFF light stays on and only 2500 RPM max
Need some advise , is it worth it to keep it ? does Millenia is a problems car ?
may be I am broke , everything about this car is expensive |
Originally Posted by thinhbui
(Post 100196)
Your 1999 mazda millenia S TCS light stays on and will not turn off and it stops your car from going over 2500RPM what is it?
Check engine lite on, OBDII reads P1113 and P1540, nice car, but I just can't figure out the problem... engine compartment is narrow to work on, Any advise is highly appreciated. |
Keninn, do you by any chance have a picture of what the plastic miller cycle cover looks like?
Miller Cycle Engine Cover
Thanks ....
change a few ft of vacuum lines, removed and install supercharge intake a couple times, then I find out it was the IAT sensor wiring loose that kept the engine rev 2500 rpm max. Now it drives, but still weak .... TCS light on, check engine on intermitten, knock sensor faulty (P0325 code ) |
(Post 100769)
Thanks ....
Thanks for all of the info guys! I'm so glad I found this forum! I just bought a 2000 Milley S last weekend for $2k with 105k and some light front end damage....(already repaired most of it)
But today the TCS issues started so I'm going to try the solutions you listed. Do anyone know where I can get some good diagrams for the most common issues? This way I can test and tackle them if needed while I'm already in the engine bay. LMK Thanks! :D |
