1995 MILLENIA PROBLEM
HI I HAVE A 95 MILLENIA RUNS GREAT OTHER THEN IT SHUTS OF WHEN EVER IT FEELS LIKE IT BUT WILL START UP 5-10 MINS LATER. NO WARNINGS NO NOTHING IT JUST DIES. DOES ANYONE HAVE ANY IDEA WHAT THIS POS`S PROBLEM IS. I HAD DIA. RAN ON IT AND NOTHING IT WENT FROM SHUTING OF LIKE ONCE A WEEK TO LIKE 5 TIMES A DAY NOW ITS TIME I NEED TO FIX THIS. IF ANYONE HAS ANY CLUE WHAT THE PROBLEM IS PLEASE I NEED HELP. THANK YOU
RE: 1995 MILLENIA PROBLEM
2.3 milly S or 2.5l engine??? If is the 2.5l then check to see if you have spark when it will not start. If no spark then odds are extremely good that the distributor is failing. Have seen a very large number of failures with this particular distributor in the millenia, 626, and MX-6. Remanufactured units now the only thing left available. Part #kf34-18-200r-0a with MSRP of $373.90. availiable online for $324. Should come with new cap and rotor but no oil seal 'O' . seal is an f201-18-201.
OK I HAVE CHANGED THE DISTRIBUTOR WITH A BRAND NEW FACTORY ONE AND THE CAR IS STILL SHUTTING OFF I DISCONNECTED THE EGR AND ITS STILL SHUTTING I AM SO LOST WITH THIS PROBLEM ANY OTHER IDEAS... ITS NOT TROWING ANY CODES EATHER I HAD IT TESTED 3 TIMES . IT HAS SHUT OFF ON HIGHWAYS AND SITTING AT TRAFFIC LIGHTS SOME TIMES IT DONT DO IT FOR DAYS THEN OTHER DAYS IT HAPPENS LIKE 1.2.3.4.5.6.7.8.9 TIME A DAY I REALLY NEED HELP PLEASEEEEEEE THANK YOU
Debris blocking fuel pick-up tube in tank?Clogged fuel filter?Bad electrical wire/connection going to fuel pump?Bad electrical wire/connection going to distributer?
HAD ALL WIRING CHECKED AND THEY ARE OK ALSO HAD NEW FUEL PUMP AND FILTER INSTALLED AS WELL AS HAVING THE FUEL TANK FLUSHED AND CLEANED WHEN IT IS SHUTTING OF IF I SIT THERE AND PUMP THE GAS IS PUTTERS PUT WILL NOT START AFTER A FEW MIN. IT RUNS LIKE NOTHING EVER HAPPENED.
