1995 Millenia P1195 code with rough idle and surging PLEASE HELP
I have a 95 Millenia and I am geting a P1195 and it idles really rough. Its a little rough in park but when i put it in gear it idles really really rough and usually ends up dying. also when normal driving it surges up and down. seems to do it more when the engine temp is at normal operating temp. I replaced idle air control valve with no change. cleaned egr ports in the throttle body and in egr its self. chased several other things around and i just need some help. Thanks.
Barometric pressure (EGR boost) sensor circuit malfunction
check codes here
http://codes.milleniatech.net/
check codes here
It is either the Boost Sensor, or if it is a 2.5l engine the intake manifold is clogged. It has to be taken off the engine & all the vacuum ports need to be properly cleaned out. They get clogged clogged from carbon buildup. Known problem on these cars.
-Sheldon.
-Sheldon.
