02 sensor connection
2000 Millenia has P0173 & p1173 codes. Located a broken t connector for the vacume lines and replaced but I think the o2 Front LH sensor may also need to be replaced. Problem is I can not trace where the O2 Sensor plug is located. It looks like the wire goes from the exhaust connection up and through a space in the engine but can not find this (four wire) connection on the rear of the engine. I was able to trace and located the connection for the upstream 02 sensor and I thought the front sensor would plug in around the same area, but no luck. Can anyone tell me where the plug goes? Thanks, Bill
Originally Posted by wschollw
(Post 126164)
