00 Millenia 2.5 auto cel code help
I have a 00 millie thats giving me and error code off a obd 2 code puller of P0173 fuel trim malfunction bank 2, i am unsure of what to do or check to stop this from occuring. i have gotten the code 3 days in a row just after start up. the first time i also got a p0170 code(same discription but for bank 1). the car slightly hesitates when initally pushing on the gas but once up and running it runs well. Any help would be greatly appreciated.
Originally Posted by sxrxndnb
(Post 100426)
bottom line, you need to check all the T/Y fittings, and replace any broken ones. the best way is to just replace all the vacuum line and fittings. i went to brass instead of the plastic. but on the 2.3, replacing the vacuum lines is like 100 times worse. |
Check you air intake hose. These are notorious on the Millenias.
-Sheldon. |
