Removing Cat
What are the general thoughts on removing the exhaust catalyst ?
thanks, gander10 |
Originally Posted by gander10
(Post 128536)
thanks, gander10 |
More trouble than its worth in most cases. They are even trying to find ways to clean up race car exhaust. If you are driving on the street, keep the cat. Your CEL and state inspection station will love you for it. :D |
Hollowing out a catalytic converter or replacing it with a test pipe or straight section of pipe is a violation of Federal Law punishable by fines in excess of $25,000 and/or jail time for both the vehicle owner and the person doing the work.
Removing a catalytic converter will result, at most, in 5 HP in power improvement. However, hollowing out a catalytic converter will cause resonance problems. The symptom is most often seen as a hesitation, popping, or backfire at or about 3,200-3,500 RPM. Upon hard acceleration, the engine will appear to cut out for a split second as RPMs drop and a split second later recover and continue past 3,200-3,500 RPM. Additional symptoms are a loud and continual popping sound when the vehicle is allowed to decelerate under load and a whooshing sound that is delayed from or following the engine speed. This is due to the open chamber within the hollowed out catalytic converter case. It loads up and releases pressure in the exhaust system that acts almost as a capacitor. The open chamber allows the formation of standing waves within the chamber which reflects back toward the engine and causes the hesitation and miss in the RPM range. Above from: ISUPAGE; Performance Exhaust System Basics your factory catalytic converters are robbing horsepower from your engine by creating a huge restriction and excessive heat in your exhaust system. To combat that, aftermarket parts companies have come up with test pipes and high flow cats for many popular applications. companies like Berk Technology have streamlined their high flow catalytic converters to a point where they have been proven to flow exhaust gasses up to 87% as efficiently as their test pipes, which is only 1.3 horsepower less per 10 horsepower gained. Above from: Test Pipes vs. High Flow Cats | I would get a hi-flow cat 1/4" bigger than stock with an exhaust pipe 1/4" wider than stock to maximize flow. Make sure the exhaust before and after your cat is also 1/4" wider as well. Sound, flow and power should be realized. On my 3.0 litre V6 the stock exhaust is 2.25", mine is 2.5" and the single flow part. Any bigger would negate flow. Check out Magnaflow. http://www.magnaflow.com/wideopen/performdata.asp |
