Rear Shock Replacement Brands
Old Mar 29, 2023 | 10:46 AM
MrTrackman's Avatar
Default Rear Shock Replacement Brands
My '11 PRHT Sport calls for Bilstein shocks. Has anyone replaced these and if so, Which brand did you use, and what effect did you notice from the change?
Thank You
Old Mar 29, 2023 | 11:41 AM
Thank You
I am not sure that was a Mazda requirement but rather a recommendation. Without knowing the exact Bilstein type/model it would be hard to compare other dampeners?
It would be almost impossible to compare with any real accuracy what other may have experienced if they did change because of the numerous amounts of possible variables that can affect ride quality and the dampeners used.
Old Jul 29, 2023 | 02:19 PM
THE CHIEF's Avatar
Default If the arm isn't threaded
If the lower arm is not threaded use a punch and beat it out . Lube up a new bold and drive it in.
Thank You
If the lower arm is not threaded use a punch and beat it out . Lube up a new bolt and drive it in.
ljs1701
Nov 12, 2017 03:54 PM
PearlWhite5
Aug 31, 2013 08:51 AM
madmike01uk
Feb 15, 2013 04:40 PM
NickC
Oct 15, 2011 12:04 PM
Mozart
Nov 6, 2008 01:57 PM
