pcm module
Not the PCM for the car Can I use one from the same yr but different PT NO. thanks
Nope. You need to match part numbers. What year MX-5?
2003 limit edition what to do replace everything key and mod ect
Like the grim_reaper said above, you would need to keep the same part number. However, I wonder why there would be different ECU part numbers for the same year of car, since there was only one engine available that year. Anyone know? |
Hello Doug Some cars have immobilizer if your pcm goes you have to replace the immobilizer also or it wont work they have to be programed together also a after market solution from motorsport uk . com [ em221 pcm] very good one it eliminates the immobilize Ron
