'93 air bag control module replacement
Greetings! I have read the other posts on the blinking light codes and mine has 10, then stops, then 10 agian. Diagnosis is an air bag control module replacement which I have purchased. I'm having a real difficult time taking off the bad module. I plugged in the new one and it works. No more blinking air bag light! Its only held by two bolts and I don't see how to get one out. I have taken off the center panel under the steering wheel so I can get access to the bad unit. I was able to get the #10mm bolt closest to the front firewall but I can't see how to get access to the other one (closest to steering wheel). Its just too tight in there. I'm 6'2" and by no means a contortionist. Any help would greatly be appreciated so I don't have to go the chiropracter
