1993 steering column cover crooked
They all came that way. Always thought it looked kind of goofy but have never tried to straighten one. Combination switch bolts directly to the ignition switch bracket assembly. Only way you might be able to is to chisel out the breakaway bolts for the ignition switch and see if it will allow you to rotate slightly. Is not likely as the steering wheel lock mechanism is usually indexed to the steering shaft.
Mazmart Trini
Mar 15, 2012 09:27 AM
