Mazda Forum Help & Suggestion Center Forum for members experiencing problems with the board or those who have suggestions to make the forum better.
Cannot see pictures in posts
Old May 6, 2023 | 10:23 PM
schmieg's Avatar
Default Cannot see pictures in posts
I've been a member here for several years, but I have noticed over the last several months that I am not seeing pictures in many of the posts. I often only know this by references to them by other posters. I haven't found any settings that seem to address this problem in the FAQ and my searches have turned up nothing helpful. Can anyone help me address this problem? I'm running Firefox on Windows 11 Pro.
Thanks.
Old May 7, 2023 | 09:00 AM
Thanks.
If this happens on multiple devices then I dont know what the cause? But if a single device then this is what I do.
Try doing the normal things:
Clear History
Clear cache
Do a complete Disc clean up
Clear and reset default browser settings.
Check your latest Update and see if security setting were changed.
Lastly completely delete the forum from your computer encoding passwords and reinstall do all of the above and reinstall the forum.
If the forum had an update your computer may not have accepted all of them and a reinstall may be what is needed?
If that don't work IDK????
Old May 7, 2023 | 10:20 AM
schmieg's Avatar
Clear History
Clear cache
Thanks, I'll try those. I see some pictures, yours are usually there, but Lobstah's and others are often just blank messages.
Old May 7, 2023 | 10:37 AM
schmieg's Avatar
Callisto, thanks. I put the forum into an exception for blocking pop-ups and deleted the history and it seems to be working now.
Old May 7, 2023 | 11:37 AM
glad to read it/ BTW you are the very first ever I have given any form of advice concerning computer operations other then a vehicles ECU. And only because it had happened to me more than once and I had help to cure it and watched carefully and learned. LOL Normally I run for those that know this and there are a few on this forum. I was just responding early this morning otherwise I am sure a couple of our regular members would have responded as well to your question!
Cheers.....
Old May 8, 2023 | 09:17 AM
Robb M.'s Avatar
IB Staff
try turning off your VPN.
Old May 8, 2023 | 09:39 AM
schmieg's Avatar
I think we have a winner. Clearing history only partially works.
Kellen
Feb 19, 2021 05:42 AM
josrod78
Dec 30, 2020 03:19 AM
TRIPP
Aug 25, 2014 09:20 AM
