Mazda Forum Help & Suggestion Center Forum for members experiencing problems with the board or those who have suggestions to make the forum better.
High beam actuator problem
Old 11-17-2017, 02:35 PM
shaolinroca's Avatar
Default High beam actuator problem
Hello everybody, I have a 2010 Mazda 3 Grand touring, it is a rebuild car, so it has a few details, one of them is that the right high beam doesn't work, after a few research I realized that the current actuator is not the best for the car, because it lacks of the connection for the right high beam.
I mean I got literally a loose cable hanging there because I don't have where to plug it.
Any suggestions?
Ps. I pretty sure that thing controls the elevation of the lights, cause mines always points to the floor
this is the actuator my car has
Old 11-17-2017, 07:35 PM
Have a look at the LHS headlamp setup, the RHS will have all the same parts & setup.
Old 11-18-2017, 12:50 PM
Sorry I don't understand, do you mean like autozone? because I went there and they don't have it
Old 11-19-2017, 05:31 AM
No, you have two headlights, they will both have bulbs and the actuator, if your missing something off 1 side, look at the otherside to see whats missing.
Old 11-20-2017, 02:55 PM
Got it, thank you
Actually I did that with my former mechanic, and that is what we discover, I mean:
- There are a set of cables running from some part of the car to the headlights, one of them is hanging because I don't have where to plug it.
- We made the test of unplugging the left HB from the actuator and plug it the right one and it worked
- The current actuator is attached to the car with a cable tie belt, I search it and it appears to be for a lexus not mazda
I think I need a new actuator with two connections? or get a tricky electrical connection?
sevargmt
09-17-2013 01:36 PM
Epoxy
01-05-2010 10:05 AM
thelordparadox
06-13-2009 08:58 PM
mazda guy
04-27-2009 07:48 AM
57chevy
06-02-2006 01:06 AM
Quick Reply: High beam actuator problem
