Roof Rack
Old Jun 27, 2020 | 01:14 PM
Laidback's Avatar
Default Roof Rack
Just got my 2016 CX-9. I would like to have a roof rack. It does not seem to have any type of cross or other attachments on the roof. Trying to figure out what I need. By the way it does have a sunroof. Any pointers would be greatly appreciated. Tess
Old Jun 28, 2020 | 02:29 AM
You drill thru the channel rubbers & bolt roof racks into the provided locations. ( requires removal of gutter rubbers to locate drill hole positions)
You get alot of wind noise with the sunroof open & roof racks fitted.
https://www.mazda.com.au/accessory/TC11ACRR -- example -- or https://www.sparesbox.com.au/part/pr...SABEgIs5vD_BwE
Old Jun 28, 2020 | 11:31 AM
Bronco Boy's Avatar
Aftermarket racks will clamp on.
https://www.thule.com/en-us/buyers-g...ks&q=Rr2RGyERE
Old Jun 29, 2020 | 01:30 PM
ant.gen's Avatar
I had the same question as Laidback. So, you're saying that all CX 9s have fixed points on the roof, it's just that some are not accessible through the rubber strips? Do you know if they make replacement strips that can provide access to these fixed points and can be closed off when no rack is on?
Old Jun 30, 2020 | 12:01 AM
All CX-9s have three mounting positions welded into the roof structure. The factory Mazda roof racks come with dummy plugs to fill in the drilled holes in the gutter trims.
Old Jun 30, 2020 | 12:53 PM
PTguy's Avatar
Both Yakima and Thule racks clamp to the roof. Rhino-Rack screws to the strong points in the roof after the rubber strip is cut away in those spots. Thule, maybe others, says to avoid opening the sun roof when the rack in in place.
An alternative is to buy the factory roof rails (number 0000-8L-N10B) ($325 on line) as well as the factory cross bars ($150 on line). Amazon has a bunch of off brand cross bars for less than the cost of factory bars.
Old Jul 6, 2020 | 09:33 AM
memphiscx9's Avatar
I'd be interested in hearing and seeing what Non OEM racks others have installed. Just got a '14 that needs one. I have one on my previous '13 OEM and it was fine. Thanks...
Old Jul 29, 2020 | 08:12 PM
nyglobal's Avatar
If you are in NJ I have a free Thule Rack (bought it on 2013) I used it on my CX-9 until I removed it last year since now I don’t use the mazda for long trips.
Old Jul 29, 2020 | 08:15 PM
nyglobal's Avatar
By the way all these after market parts adapt to the car standard roof (there are factory holes made already in the roof with small plastic covers). It takes about 30 min to install the first time😎
Old Jul 31, 2020 | 11:11 AM
memphiscx9's Avatar
Thanks for the offer and I'm definitely interested. Is this a system with square or elliptical bars and will the towers mount into the fixed holes? I'm in Memphis but I could pay you for shipping and materials and your time.
