-   Mazda CX-9 (https://www.mazdaforum.com/forum/mazda-cx-9-50/)
-   -   Replace 2016 CX-9 OEM Wipers (https://www.mazdaforum.com/forum/mazda-cx-9-50/replace-2016-cx-9-oem-wipers-37620/)
kuzindwight Dec 19, 2016 07:47 PM
I live up in Alaska and the stock wipers are HORRIBLE in the subzero temps. I'd like to replace them with some Rain-X wipers but I've never seen these type of blades mounts. They look like they are Push Button Lock (PBL) but PBL replacement arms don't fit. The owner manual just tells you to change the blade and not the whole arm. I'm really not a fan of their stock blades but I appear to be stuck with these things that don't work well.
Anyone else figure out how to upgrade blades? Maybe I'm just crazy but I'm stuck.
Thanks, Jaysen
PTguy Dec 19, 2016 11:12 PM
Jaysen, if you contact Anco and Trico, please let us know what they say. I'm not sure who makes the wiper blades for ITW Global brands marketed under the Rain-X brand. You might send them some photos of both the type of blade lock and the insert.
kuzindwight Dec 22, 2016 03:08 AM
The Anco and Trico websites don't even have a blade listed on their "blade finder" for the new CX-9. Rain-X and Bosch say their blades will fit but I've had no luck figuring out how to install the Rain-X. I haven't tried the Bosch yet.
vintovka Oct 13, 2018 02:07 PM
Know this is old but looking for replacement wipers on mine. I know Michelin and Goodyears DO NO FIT. Attaching parts maybe unique to this year and model.
PTguy Oct 13, 2018 02:11 PM
You have three easy choices:
Mazda inserts. It just takes a couple of minutes to slide the old insert back then out of the slot on the bottom, and slide the new one in.
Trico ExactFit 24-17B & 18-17B. The rear is 14-A
NAPA re-labeled Trico ExactFit
There are no known winter blades yet.
vintovka Oct 13, 2018 02:24 PM
Thanks for fast reply - will try the NAPA as we are 40 -70 miles away from other stores.
PTguy Oct 13, 2018 02:30 PM
I got the Mazda inserts from a dealer on eBay for about $20 delivered.
vintovka Oct 13, 2018 03:10 PM
Thanks Again. Were they hard to install? BTW some wiper sellers are saying Madza provided incorrect specifications to many of the aftermarket makers which may be reason I just wasted an hours trying all the combo fittings on a set of Goodyears.
PTguy Oct 14, 2018 01:24 PM
The blade inserts are easier to install than to describe. Lift the passenger wiper arm. Push on the square pushbutton and pull the wiper blade free from the arm. From either end, slide the rubber insert away from the lump on the tip. Compress the rubber insert back into itself. It takes a pretty good pull. As soon as it slides past the end lump, you'll see a slot. Let the insert go out the slot to remove it. Put the new insert back into the slot the same way.
LJL11 Mar 24, 2019 08:02 PM
2018 CX-9 Wiper Replacement Difficulties
I have a 2018 CX-9 that even with the OE version of the Bosch ICON wipers needs some type of adapter in order to fit on to the wiper arm. In your post you mentioned Mazda inserts. Do you have a part number for the inserts or better yet a link to the part that you purchased that solved the problem for you.
Thanks in advance.
