Issues with Gracenote Update
I attempted to update the Gracenote in my 2018 CX9. I currently have version 00.09.000 (really old). I confirmed the file was properly loaded onto my thumbdrive. When I go to update the database in my car it recognizes the thumbdrive, then tells me "no update available". I also confirmed its not in a sub-folder. I have used this same thumb drive to successfully update my firmware. Please help!
Format your thumb drive, reload gracenote software update onto it & try again.
Gracenote update still not working
I re-formatted my thumb drive and tried again...my car still says “no update available “. I’m at a loss...can someone please send me the link to the latest update...is their an issues because of the file type maybe?
I've been having the same problem with my 2017 CX-5. I can't believe there are only 2 people with this problem - there must be more.
Mazda, sadly, is terrible when it comes to updating the infotainment system. |
Originally Posted by eebusman
(Post 185675)
It's version 9 on my 2018 CX-9 and trying to update with the latest download from the Mazda site on my USB drive (tried both ports) it says the same thing: "no update available". I have tried three different USB sticks (two freshly formatted etc).. and still no result. Hopefully someone has a solution. |
Make sure the USB stick is formatted as FAT32
Since I was also wondering about this and couldn't find the answer, the problem is the newest gracenote updates are in .mcg format and the older mazdas only uses .up format for gracenote.
Gracenote Database. To the OP FYI Connect 1 systems version 00.09.000 is the latest and last Mazda will release. For Connect II systems go to the posted link they're in .mcg format select the correct region and follow print instructions. Gracenote is also included in MZD firmware and can be updated by dealer when car is in service.
Gracenote ?
What does Gracenote do? 2023
my cx5 2021.5 always says No Updates. What version should it be as of 9th June 2023? thank you |
