Front end noise
All 4 rotors and pads replaced. Noise still exists. I have noticed one caliper boot is torn, ordering replacement.
No movement up and down or side to side, so I not thinking wheel bearing. ? Thank you, Steve |
I Change the Front Upper Strut Mount TD11-34-380B for a "Bird singing" noise.
Front end noise
The shield behind the rotor could be touching the rotor as it spins. Try pushing it back a bit. It has happened to me before.
So far, the fix changing the Front Upper Strut Mount TD11-34-380B, works fine. No more singing birds or knocking. Good look.
