-   Mazda CX-9 (https://www.mazdaforum.com/forum/mazda-cx-9-50/)
-   -   Diagnostic scan faults: ABS lost communication with Instrument Panel Cluster (IPC) (https://www.mazdaforum.com/forum/mazda-cx-9-50/diagnostic-scan-faults-abs-lost-communication-instrument-panel-cluster-ipc-52277/)
Paul56609 Jul 17, 2023 08:56 PM
Hello all,
I would like to get advice on some faults I recently detected on my Mazda CX-9. The faults show up when a diagnostic scan of the engine is run. I don't see any faults on the dashboard otherwise but I'm a bit concerned. Sometimes I get the faults and other times, it clears up. Any suggestions or advice will be appreciated. I would like to take preventative actions in case this is an indication of a more serious problem.
SYSTEM CODE DESCRIPTION STATUS
ABS (Anti-Lock Brake System) U0155:00-8B Lost Communication With Instrument Panel Cluster (IPC) Control Module Continuous Memory DTC
FSC (Forward Sensing Camera) U0415:68-0A Invalid Data Received From Anti-Lock Brake System (ABS) Control Module A Continuous Memory DTC
SBS/MRCC (Smart Brake U0316:09-8A Software Incompatibility With Vehicle Dynamics Control Module Continuous Memory DTC
Support/Mazda Radar Cruise
Control)
Thank you.
Paul56609 Jul 17, 2023 09:06 PM
Originally Posted by Paul56609 (Post 217734)
Hello all,
Control)
Thank you.
Some other errors which show up intermittently after a diagnostic scan.
SSU#1 (Start Stop Unit) U2300:00-0A Central Configuration Continuous Memory DTC
TCM (Transmission Control Module) U0155:00-AF Lost Communication With Instrument Panel Cluster (IPC) Control Module Continuous Memory DTC -
grim_reaper Jul 21, 2023 07:40 AM
U codes are communication fault codes.
Unless you are experiences issues, you can ignore U codes.
