Automatic Unlock Function
I just recently bought a 2013 CX-9. When I unlock the car using the button on the handle, it will occasionally make the driver seat lay back fully. Is this an auto unlock feature? I looked through the manual but was unable to find anything.
Thanks! |
Are you sure the key is not coded to the seat memory? Set the seat to where you want it and press Unlock on the key. If you here a beep then the seat has been associated with the key. Not familiar with the 2013 but on the newer models this is the way it works.
