Air con stopped working
Hi gang, I've got a 2012 cx9
Jumped in to go for a drive & the air con is not working at all in the front, the rear however is working fine , I've done a bit of reading, it suggests a faulty relay . Does a damaged relay sound right or something else Thanks |
I am assuming the blower motor is not working? Yes, the relays were a concern. dealer has an updated relay available. I have also seen many blower motor failures due to clogged drain tubes that allow water to accumulate in the ducts and drown the motor.
