2017 Does Apple Carplay Retrofit Remove the existing Mazda Navigation
Old Jun 18, 2020 | 10:00 PM
ManiZ's Avatar
Default 2017 Does Apple Carplay Retrofit Remove the existing Mazda Navigation
Hi All,
Just bought my first CX9 a 2017 CX9 LTD (the full option) and as part of this the dealer agreed to retrofit Apple car play. Whilst doing this the dealer broke and had to replace the touchscreen display as well.
Just took delivery of the car and found the Apple Car Play works but it does not have the old Existing Mazda Navigation installed. It now says “Your Mazda is not equipped with a Navigation System however an integrated Nav system is available from your Mazda Dealer...”
1. When I install Apple Car Play should it remove the existing Nav? I don’t think this should be the case?
2. To reinstall the Nav will the Dealer have to find the old SD card from the old USB unit or do they just do a software update?
3. Would this be covered under their used car warranty?
4. Does Android Auto come as part of the Car ally retrofit or is this an additional upgrade?
Thanks in Advance
Old Jun 19, 2020 | 12:39 AM
The SD card for the sat nav is required to run the Factory Mazda Sat Nav. I would be asking them to supply a SD card.
Old Jun 19, 2020 | 07:54 AM
ManiZ's Avatar
Thank you.
i know it had an SD card before, I assume they left it in the old USB module.
hope to learn lots from the forum!
Old Jul 23, 2021 | 10:00 AM
rache64's Avatar
[QUOTE=ManiZ;184430]Thank you.
Hello, Did you ever get the factory nav to work after the retrofit? I am considering the same - upgrade to Carplay/AA on my 2018 CX-5 but
want to keep the factory nav as well. I hope this upgrade does not cost original functionality. Thx
Old Jul 24, 2021 | 12:01 AM
It has zero effect on the factory Satnav.
mahatabur
Dec 3, 2019 09:59 PM
Kzneft
May 20, 2019 11:10 AM
mazda_nc_dude
Oct 21, 2018 09:34 AM
Jennifer Arvan
Feb 7, 2018 01:37 PM
Vinipizz
Feb 3, 2018 12:00 AM
