Manually reset the check engine light
Old 10-19-2007, 01:02 PM
ripull's Avatar
Default Manually reset the check engine light
Basically I left the ignition Key on and one of the Doors left open overnight, this obviously drained the battery to the point where I needed to jumpstart the engine. Once the engine was started and the battery was charged I had to reset the Clock and program the AM/FM channels. This was the only thing done and yet the Check Engine light came on and has not turned itself off. Because the battery was completely drained I am sure this was what triggered the engine light but unfortunately I am not sure if the Customer can reset this?
My question is do we have any way to resent this manually without taking to the dealer?
Thanks in advance
Old 10-19-2007, 01:32 PM
hixx's Avatar
Default RE: Manually reset the check engine light
Disconnecting the battery and stepping on the brake pedal a few seconds should reset it. It probably set an O2 heater code due to low voltage on startup.
Old 10-19-2007, 01:54 PM
ripull's Avatar
I will test this
Thanks
~ripull~
honeybadger11
07-19-2011 10:35 PM
scotthochgesang
04-11-2011 11:00 PM
ichimazda6
01-31-2009 09:27 PM
bayarea96lx
04-16-2008 02:33 AM
wirelesscop
10-17-2006 03:15 PM
Quick Reply: Manually reset the check engine light
