Reseting shift adapts 07 cx7
Going to be changing the valve body on my CX7 it’s a 2007 and was curious if anyone knew the procedure to reset the shifter adapts after I’m done |
Disconnecting the battery & pressing the brake pedal will reset all learned values.
Ok did that thanks cars gonna sit with batt disconnected all week got all prep work done Drained fluid Removed airbox removed driver inner fender plastic removed cooler lines moved some wiring harness bits back got cover off part comes tuesday ill be swapping next week |
