Need help with After market radio installation
Hello, I have a Mazda CX-7 2.3 2009 and I bought a radio Teyes cc2plus. I tried to install it in my car but it doesn't work correctly there is no sound and I don't know why. I connect everything I could. Do I need an additionnal harness in ordre to make it work?
Does your CX-7 have the Bose system?
Did you buy a plug & play adapter loom? |
(Post 201837)
Bose system needs extra bits or setup for aftermarket head units. I would contact a car audio shop.
I don't know what to do I contact the vendor but he doesn't care about the problem. I try to contact people in other forum to try to get some helps but no solution was found. Only that I should connect the blue wire named amp-con and acc wire. It doesn't work.
