cx-7 no start issue, check engine light wont clear
Old 01-13-2018, 05:46 PM
topfli8979's Avatar
Default cx-7 no start issue, check engine light wont clear
I found a cheap 2009 cx-7 that will not start. Has 56,000 miles. The check engine light is on and after key is turned it flashes a few times then goes solid. I have tried using 3 different obd2 scanners. None of them will pull up any codes or clear check engine light. I can get the engine to hit every once in a while but it will fall on its face within a second, even with throttle applied. Exhaust pipe smells very rich. Pcm does make a clicking sound after attempted start, and there is a whine/buzz sound coming from somewhere under the intercooler.
Also I did not know about the extent of the timing chain issues on these motors before I purchased it. I hope that is not my issue. I pulled the oil fill cap and there is slack in between the cam wheels, is any slack acceptable?
Old 01-14-2018, 12:56 AM
How much slack?
Old 06-25-2018, 11:26 AM
Mazdaboy75's Avatar
Default Slack
Should have by finger touch about 1/8"/1"4 play. You'll have a little with the tensioner and chain. Normal. If everything was rock solid 10000% tight. The engine wouldn't turn over. Too much so your looking at a chain tensioner issue. However....
That won't be your issue for non start. I've found a lot of scanners won't pick up the Mazda could for some reason. My Mac one will and another Nova one I have. 3 other guys at the shop when they started wouldn't. Did updates and 1 worked the other 2 had to buy better scanners. Gilave weird codes with $&# symbols. Goodluck
RyanL
03-29-2016 10:28 PM
greasegeek
14
01-31-2015 12:40 PM
shaffer20
10-06-2008 09:15 PM
Mr. Mojo
05-23-2007 10:31 PM
Quick Reply: cx-7 no start issue, check engine light wont clear
