-   Mazda CX-7 (https://www.mazdaforum.com/forum/mazda-cx-7-44/)
-   -   2010 CX-7 jerky acceleration from complete stop (https://www.mazdaforum.com/forum/mazda-cx-7-44/2010-cx-7-jerky-acceleration-complete-stop-45559/)
djrolla Sep 25, 2020 05:31 AM
I've read a couple of other threads in this forum addressing the same problem, but I didn't find a solution anywhere. It seems like a lot of people that replied to those threads dismissed it as just perception of the driver and nothing mechanically wrong with the vehicle. Does anyone know what I can do to fix this? Here's what happens, from a complete stop when I press the gas, even if I push as gently as I can, the car bucks off like I floored it and all passengers get minor whiplash and look at me like I'm crazy. When other people drive my car I get mad at them for driving like that lol. Does anyone have any bit of advice on what to do? It's not my perception, the car jumps no matter how soft you hit the gas. Thanks for reading.
grim_reaper Sep 25, 2020 06:10 AM
Has is been scanned for fault codes?
When was the PCM/ECU software last updated by Mazda?
djrolla Sep 25, 2020 09:35 AM
Thanks for the reply grim_reaper. There aren't any fault codes, no check engine light and it just passed smog. And has the PCM/ECU software been updated? I have no idea, I didn't know that was even a thing. How would I be able to find out the current version? And can you recommend a way to update it? Thanks again.
grim_reaper Sep 26, 2020 03:06 AM
Only a Mazda dealership can update the software.
Is your CX-7 auto or manual transmission?
djrolla Sep 27, 2020 04:53 AM
It's an automatic 2.5L.
djrolla Mar 5, 2021 03:17 AM
Just wanted to give an update about this and what I did to fix it. The throttle body needed a good cleaning. The carbon buildup was causing it to get stuck and pressing the gas pedal would make the car jumpy. After the cleaning it rides so much smoother.
Jgeezy Apr 22, 2021 09:01 AM
Thank you for the follow up, tried this and was incredibly successful. Accelerates smoothly and is no longer jumpy at acceleration
brandon021 Apr 28, 2021 07:53 PM
djrolla's suggestion totally worked for our jumpy CX-7. Had been driving me nuts forever, and cleaning the throttle body did the trick. Thanks djrolla!
spirosk Aug 10, 2022 03:11 AM
hello. :)
I would like to ask you, when you say cleaning the throttle, what exactly do you mean? i mean what is the procedure? did you take out the whole body or with some spray with the body on the car?
thanks in advance
djrolla Aug 10, 2022 02:35 PM
I'm glad it worked out for ya.
