well I have a 2007 cx7 with a bad engine. I just got a wrecked from rear donor 2010 with the 2.5 and was wondering if its just a motor swap, or have to swap pcm, harness. also will the trans that's in my 2007 accept the 2.5 engine? thanks.
do you have the whole 2.5 vehicle ?
Originally Posted by duckboy
(Post 174997)
? duckboy
You are gonna have to swap the engine/trans combo and use a good chunk of the the 2010 interior,
You will have to swap almost every piece of wire and every module. Basically plan on gutting your entire 07 interior and replacing a lot of it with the 2010 https://imgur.com/a/wG4dbG9 Here are some pictures from my swap, If you have emissions you may be screwed. |
Cx7 2.3 to 2.5 swap.
Thanks a lot for the help duckboy. By modules u mean pcm,bcm, instrument cluster? The important ones or also like modules like the rcm? [QUOTE=duckboy;175026]You are gonna have to swap the engine/trans combo and use a good chunk of the the 2010 interior,
You will have to swap almost every piece of wire and every module. Basically plan on gutting your entire 07 interior and replacing a lot of it with the 2010 https://imgur.com/a/wG4dbG9 Here are some pictures from my swap, If you have emissions you may be scre |
Swap 2011 2.5 Aspirated into 2008 turbo
Hi Duckboy,
I have a 2011 Aspirated 2.5 Mazda CX7 and am wanting to put basically just the engine into the 2008, would love some advice on what issues I might come across with the conversion. Wanting to keep the 2008 interior, dash and everything except for the engine. Thanks and hoping you are still checking this thread :) |
