Will Rim size 18 x 6.5 fit CX 5, 2020 Signature model?
Can someone answer this for me. I could not look this up on few websites.
i have 19 inch tires on my 2021.5 CX 5 Signature turbo, but want to put on these 18 x 6.5 Rims. The Question is will these rims fit?
I purchased these used tires and rims from a 2017 Cx5 with 18x6.5 rims. Will these rims fit?
Dont worry about tire the tire will fit. BUT NOT SURE OF RIMS
Thank you
Thank you
What's the offset of the 18" rims? What's the stud pattern? What's the PCI?
https://www.wheel-size.com/size/mazd...m-25i-usdm-187
Hi grim_reaper thank you for the link which i am aware of. Unfortunately that does not tell me the full details. I want to go from stock 19 to 18 inch. And want to know which 18 inch rims will fit.
Some rim depth is not adequate for front brake caliper. So how do i find out Depth of rim is adequate to clear brake calipers.
Stud pattern and PCI do match, but that does not mean depth clearance is there.
For example the stock Mazda cx5 spare tire on 2021.5 model will NOT fit on front wheels, only REAR axle. Due to brake calipers.
Hi grim, ok so here is what i found..
Original size of rims tire could be
for 225/55/R19 inch stock it could be one of these:-
7.5J x 19 x ET45 or 7J x19 x ET45 ( i don't know which one is stock on this car currently). Note 0.5 difference.
The 18 inch i want to install are 225/60/18
7J x 18 x ET45
the 5 bolt pattern 5x114.3 is sane for ALL, as is Center hole 67.1.
but if old is 7.5J and new is 7J will rim fit?
Also note the 19 inch inner rim diameter is 483mm and 18 inch is 457mm. Therefore a reduction of 26mm. Will this clear front calipers?
7J x 18 x ET45
If the 18 inch wheel in question was previously on a CX-5 then I suspect it will fit on your CX-5.
