When should I change CX-5 drive belts?
When should I change CX-5 drive belts? Is there a mileage they generally need to be replaced? The manual just says to inspect them. |
Originally Posted by Sav04
(Post 173394)
Yeah I agree. Do your inspections and check for a leaking hydraulic tensioner and if the belts are contaminated by oil or cracked or glazed. If none of that and they are still quiet then you can wait for the 100k miles. Thank the old belts for their service and celebrate by installing new belts. Don’t forget the ac belt requires a small tool investment to install a stretch to fit belt. |
Check/inspect every service. R&R if signs of wear.
What does your owner's manual say as a suggestion ?
Owners manual says "I" (Inspect) @ each service
