Unable to locate the oil reset functionality (after oil change)
On my MY 2015 (delivery date - May 2014...EARLY MODEL) Mazda CX-5, I'm unable to mimic the 'locate MAINTEANCE' when following these direction -
1 Turn the ignition to ON position without starting engine. 2 Press the UP/DOWN arrows on the INFO switch to highlight the 'Setting' menu and press the INFO button to confirm. I don't have a 'Setting' menu available to me. Suggestions (or being told my vehicle doesn't have one!) welcome. |
Apologies, meant to say I couldn't find the 'SETTINGS' menu. (the MAINTENANCE menu is supposed to be under the SETTINGS menu.)
If you have the menu similar to the current Mazda’s, Try looking under APPs on the far left of the menu. Not sure if it is there on your CX-5 but is is on my 15 3. |
Thanks for your help mazdaCPA. Finally found/read owner's manual. States 2 different gauge setups for cx5. Appears I have them type 'B' layout. 'A' has lengthy description on how to reset it. 'B', doesn't mention a reset. Suspect 'A' is for grand touring model, I have a touring model. Just weird that Mazda wouldn't provide the feature.
I was just about to post about Type A vs Type B.
Yes, grim_reaper, appears my model was built SO early in the model year, the vehicle must be closer to the 2014 MY Thanks, everyone.
