Trailer hitch & wiring
Old May 27, 2023 | 04:39 AM
  #21
BobW's Avatar
Originally Posted by MrCole
Would you happen to have the wiring diagram that came with your kit so I know what wire does what? I can’t seem to find it or any instructions instructions for it online.
Here you go, I would check the output at the four pin plug withthe trailer disconnected. If both right and left signals are working and the brake is not, the problem is in the converter box.Good luck.
File Type: pdf
Old Jun 1, 2023 | 09:58 AM
  #22
MrCole's Avatar
Default Big thanks to BobW!
I was able to use the diagram you put up, find the brake light wire and reseat the connector and it worked! Saved me a couple hundred dollars and it took me less than an hour. Big thanks
Old Mar 31, 2024 | 01:31 PM
  #23
lschwarcz's Avatar
I know this is an older thread but this past week I finally got around to installing the wiring harness on our 2020 CX5. I installed the factory hitch way back when we bought it new and just never got around to the harness!
As another member posted here (sorry I forgot your username) don't bother with the, "Supplemental Trailer Hitch Harness" or the "Reroute" kit. It's just seven 14" black zip ties and the instructions that you can download electronically.
It guess the original instructions routed the harness a little too close to the exhaust and gives instructions on how to disconnect the wires final plug to where it goes through the grommet into the rear of the car and how to then a better route to keep it a bit further away.
Since I was installing the harness for the first time I had to follow the reroute directions backwards.
I'll try to attach the reroute directions here.
Good luck everyone!
Larry.
File Type: pdf
firefox111
Dec 19, 2018 11:42 PM
NewboldMaz
Sep 16, 2018 01:30 PM
browntown3
Jul 9, 2009 03:41 PM
8trackelvis
Jul 5, 2005 07:11 PM
