-   Mazda CX-5 (https://www.mazdaforum.com/forum/mazda-cx-5-54/)
-   -   Mazda Cx-5 gls 2016 (facelift) car wobbles (https://www.mazdaforum.com/forum/mazda-cx-5-54/mazda-cx-5-gls-2016-facelift-car-wobbles-47076/)
GurSanjeet Singh 04-21-2021 12:58 AM
Hi guys, i need some advice...I own a Mazda CX5 gls 2016 2nd hand....The car is perfect in all ways, the only thing is that it wobbles even at low speed? im using a new 19inch tires. is it common problem?
pls advice thanks.
CarpeDiem 04-21-2021 06:52 AM
No, not a common problem as these vehicles drive smoothly. Can you better describe what “wobble” meads? Does the steering wheel shake? Is there a vibration? Can you tell where the wobble is?
GurSanjeet Singh 04-22-2021 10:56 AM
It shakes alot more than a standard SUV
CarpeDiem 04-22-2021 11:20 AM
Based on you limited explanation and not answering my questions, there is something wrong with your CX-5. It may be poorly balanced tires or out-of-round tires (not as uncommon as many think). It could be a bent wheel. It could be bad wheel bearings. It could be a bent axle. It is impossible to tell from half a world away. I hope you can find and correct the cause of the shaking.
JPMAZDA 02-07-2022 12:29 AM
Hopefully you've got this issue figured out by now. But if it shakes a lot even while not moving it might just be an engine mount
