Mazda CX 5 2016 replacement fwd brake rotors
Hi all!
i am owner of Mazda CX 5 2016 2,2 td 150 hp I want to replace full set of brake rotors and pads. I have problem with finding new set of fwd brake rotors. As I can see during online browsing, there are fwd rotor brakes for model unitil 04.2015 and 08.2015. but mine is later. Did any of you had any experience with replacement of mentioned? What is the diference between prefacelifted and facelifted model brake rotors? Be careful on the road, enjoy your Mazdas and happy new year! |
https://www.partsgeek.com/ymm/2016/m...pop&scat=brake
You can also try Amazon. I guess I have a great 2016 CX-5 with 113k miles and original brakes. |
Thanx a lot for help!
Mine has 73000 km. I spoted 2 cm wide rust line on rear brake rotors, and since I'll replace rear ones, ill replace fwd set also. Happy new year! |
New rotors are not that expensive if you buy OEM style, but you can get into big bucks with performance rotors and pads. Be aware that the cheapest units will probably make excessive noise and not feel right. Spend wisely.
Thank you!
Thank you for advice!
Mazda dealer service is asking me 900 USD for replacement of 4 rotors and pads, but I can buy all this of good quality for 400 USD. I dont understand why is such a big diference in price. |
Originally Posted by Robert Babić
(Post 172042)
Last brake job (Honda CRV) I supplied new rotors @ $30 each and Goodyear supplied the pads which they got from across the street at Autozone. I think I paid somewhere around $99 an axle for labor which is not cheap considering it took < 45 minutes to do the whole thing and rotate wheels.
