Infotainment system
I just bought a '19 CX 5. How do you turn off the infotainment system?
You can go to Settings. Then to Display. And then Turn Off Display.
Explained also in this video: You can also mute the radio and it will be in mute mode even if you restart the car. |
You can only mute, or turn down the volume.
Grim Reaper is right, I can only turn off the display. The radio is still on. There is nothing in the owners book about shutting off the radio. This is my only complaint about the car.
It only turns off the screen, the radio is still on.
Originally Posted by pjs
(Post 175179)
(Post 175179)
pretty much everything you can ask about this is in the owner manual . at least it was for me ..
I agree with the concern about not being able to turn off the radio. Mute is not the same. When I am listing to an audio book, hit traffic and need to focus, I would like to be able to stop the audio. The only way is to go into the menu and pause the book which is more than I want to do at the time. It would be great if the Mute actually turned off the system, and therefore, pausing the audio.
The two options mentioned in this thread are valid but do not accomplish the desired result. You can turn off the display and mute the audio neither accomplish the desired result of turning off the radio. I wonder if there is advanced programming that can reprogram the mute button. Is anyone doing advanced programming to their infotainment system? |
The biggest problem I have with the radio/entertainment system is the dreadful amount of time it takes to load, after you start the car.
Th cx5 is a great vehicle. the entertainment system is the only flaw, imo. Mazda really needs to address this. |
