Help Needed: Error Codes
I have a 2012 Mazda CX-5 that i imported from Japan about 9 months ago. When I started yesterday morning, I got engine check light and errors with SCBS, TPMS and traction control warning light is illuminated. Car is almost undriveable. Seems as though it keeps braking and is very jerky (bucking). Car drove issue free the night before. I however did leave a hood lamp on by mistake and i would sometimes get before an error about power management system and the I-Stop would not work...it would be flashing orange. Don't know if problems are related. I took car to the closest technician. He scanned and picked up several codes: U0001, P061B, P0A8D, U0401 and B11D4. He cleared them and might have reset and car drove fine. Used for a few a hours and parked for around 5 hours. When i restarted the problem reoccurred. Any assistance will be greatly appreciated.
DTC P061B:00
Internal control module torque calculation performance problem
DETECTION CONDITION
• Indicates an error occurred in the PCM.
P0A8D is related to low battery voltage.
I would start with disconnecting the battery, getting it fully recharged, properly tested & take it to Mazda for a PCM software update check.
DETECTION CONDITION
I replaced battery, had PCM updated but problem persists. Any ideas? By the way, i used Forscan and got these results....Used Forscan......
disconnected
(WARN) [20:36:39.395] Checking Bluetooth (00:1D:A5:00:03:8D)...
(OK) [20:36:46.324] Adapter: ELM327 v1.5
(OK) [20:36:48.097] Connection to vehicle has been established
(OK) [20:36:52.432] Vehicle: Mazda CX-5 PE 2.0L SKYACTIV, VIN: KEE***05224
(OK) [20:36:56.445] Found module: TCM - Transmission Control Module
(WARN) [20:36:57.640] DTCs in TCM: U0442:00-2F
(OK) [20:37:01.682] Found module: PCM - Powertrain Control Module
(WARN) [20:37:02.316] DTCs in PCM: P0102:00-AF, P061B:00-AF
(OK) [20:37:02.405] Found module: OBDII - On Board Diagnostic II
(WARN) [20:37:03.473] DTCs in OBDII: P0102-C
(OK) [20:37:04.378] Found module: ICA - Smart City Brake Support
(WARN) [20:37:05.255] DTCs in ICA: U0401:68-28, U0415:68-28
(OK) [20:37:07.509] Found module: ABS - Anti-Lock Brake / Traction Control Module
(WARN) [20:37:09.001] DTCs in ABS: U0401:00-2B
(OK) [20:37:12.177] Found module: RCM - Restraint Control Module
(OK) [20:37:15.697] Found module: AFS - Adaptive Front Steering
(OK) [20:37:18.694] Found module: SSU - Start Stop Unit
(OK) [20:37:19.649] Found module: EPS - Electronic-Controlled Power Steering
(OK) [20:37:20.748] Found module: F_BCM - Front Body Control Module
(OK) [20:37:21.782] Found module: IC - Instrument Cluster
(WARN) [20:37:22.509] DTCs in IC: U0433:68-48, B11D4:53-48
===TCM DTC U0442:00-2F===
Code: U0442 - Invalid Data Received From ECM/PCM B
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Transmission Control Module
Freeze Frame :
-DTC: --- - DTC That Caused Required Snapshot Data Storage
-LOAD: 26.67 % - Calculated Load Value
-ECT: 58 °C - Engine coolant temperature
-RPM: 725 rev/min - Engine Revolutions Per Minute
-VSS: 0.0 km/h - Vehicle Speed
-IAT: 47 °C - Intake Air Temperature
-TP: 14.51 % - Throttle Position
-RUNTM: 6 sec - Time Since Engine Start
-VPWR: 12.13 Volt - Control Module Voltage
-APP_D: 15.29 % - Accelerator Pedal Position D
-APP: 0.00 % - Accelerator Pedal Position
-SLIP_VALUE: 56 rev/min - Absolute Value of Slip
-HTM_DIS: 0.0 km - The distance travelled since the High Temperature Mode was activated.
-GEAR_SEL: error - Gear select position
-TSS: 686 rev/min - Turbine Shaft Speed
-OSS: 0 rev/min - Output Shaft Speed.
-TFT: 53 °C - Transmission Fluid Temperature
-LOCK_UP: OFF - Toruque Converter Lockup State
-OP_SW2: Off - Oil Pressure Switch 2
-OP_SW1: Off - Oil Pressure Switch 1
-OIL_PRES_SW1: Off - Oil Pressure Switch 1
-OIL_PRES_SW2: Off - Oil Pressure Switch 2
-SS_ON_OFF: On - ON/OFF solenoid
-SS_ON-OFF: On - ON/OFF solenoid
-EOP: Off - Electric Oil Pump
-TORQUE_DES: 270.0 Nm - Desired Engine Torque
-G_INHIBIT_4: Off - Gear Inhibit - 4th Gear
-G_INHIBIT_3: Off - Gear Inhibit - 3rd Gear
-G_INHIBIT_2: Off - Gear Inhibit - 2nd Gear
-G_INHIBIT_1: Off - Gear Inhibit - 1st Gear
-G_INHIBIT_5: Off - Gear Inhibit - 5th Gear
-G_INHIBIT_6: Off - Gear Inhibit - 6th Gear
-G_INHIBIT_N: Off - Gear Inhibit - Neutral Range
-G_INHIBIT_R: Off - Gear Inhibit - Reverse Range
-EOP_RLY: Off - Electric Oil Pump Relay
-OP_SW4: Off - Oil Pressure Switch 4
-OP_SW3: Off - Oil Pressure Switch 3
-OIL_PRES_SW3: Off - Oil Pressure Switch 3
-OIL_PRES_SW4: Off - Oil Pressure Switch 4
-UPSHIFT_REV: Off - Upshift Record By Engine Request
===END TCM DTC U0442:00-2F===
===PCM DTC P0102:00-AF===
Code: P0102 - Mass or Volume Air Flow Circuit Low Input
Status:
- Malfunction Indicator Lamp is On for this DTC
Module: Powertrain Control Module
Freeze Frame :
-FUELSYS: OL - Fault - Fuel System Status (Open/Closed Loop)
-LOAD: 34.12 % - Calculated Load Value
-ECT: 61 °C - Engine coolant temperature
-SHRTFT1: 0.00 % - Short term fuel trim 1
-LONGFT1: 0.00 % - Long term fuel trim 1
-MAP: 42.0 kPa - Manifold absolute pressure sensor
-RPM: 805 rev/min - Engine Revolutions Per Minute
-SPARKADV: 10.00 ° - Spark Advance
-IAT: 46 °C - Intake Air Temperature
-MAF: 0.00 g/sec - Mass Air Flow
-TP: 16.08 % - Throttle Position
-RUNTM: 54 sec - Time Since Engine Start
-FRP: 3640.0 kPa - Fuel Rail Pressure
-EVAP_PCT: 0.00 % - Commanded Evaporative Purge
-FLI: 56.47 % - Fuel Level
-WARM_UPS: 0 - Number Of Warm-ups Since DTCs Cleared
-CLR_DIST: 0.0 km - Distance since diagnostic trouble codes cleared
-BARO: 101.0 kPa - Barometric pressure
-CATEMP11: 89 °C - Catalyst Temperature Bank 1, Sensor 1
-VPWR: 13.31 Volt - Control Module Voltage
-LOAD_ABS: 22.35 % - Absolute Load Value
-EQRAT11_CMD: 14.576 :1 - Commanded Equivalence Ratio (Air to Fuel Mixture) Bank 1
-TP_REL: 6.27 % - Relative Throttle Position
-TP_B: 15.69 % - Throttle Position Sensor 2
-APP_E: 7.84 % - Accelerator Pedal Position E
-TAC_PCT: 7.45 % - Commanded Throttle Actuator Control
-FUEL_TYPE: Gas - Type of fuel currently being utilized by the vehicle
-SHRTFT12: 0.00 % - Short Term Fuel Trim (Bank 1, Sensor 2)
-LONGFT12: 0.00 % - Long Term Fuel Trim (Bank 1, Sensor 2)
===END PCM DTC P0102:00-AF===
===PCM DTC P061B:00-AF===
Code: P061B - Internal Control Module Torque Calculation Performance
Status:
Freeze Frame :
-LOAD: 24.31 % - Calculated Load Value
-MAP: 59.0 kPa - Manifold absolute pressure sensor
-RPM: 828 rev/min - Engine Revolutions Per Minute
-SPARKADV: 9.50 ° - Spark Advance
-TP: 18.82 % - Throttle Position
-RUNTM: 5 sec - Time Since Engine Start
-FRP: 3100.0 kPa - Fuel Rail Pressure
-CATEMP11: 54 °C - Catalyst Temperature Bank 1, Sensor 1
-VPWR: 12.21 Volt - Control Module Voltage
-LOAD_ABS: 18.04 % - Absolute Load Value
-TP_REL: 9.02 % - Relative Throttle Position
-TP_B: 18.43 % - Throttle Position Sensor 2
-TAC_PCT: 5.88 % - Commanded Throttle Actuator Control
===END PCM DTC P061B:00-AF===
===OBDII DTC P0102-C===
Code: P0102 - MAF Sensor Circuit Low Input
Status:
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
Diagnostic Trouble Code details
This DTC is set when the MAF sensor signal is lower than normal.
This DTC may be caused by :
Sensor
Improper connection
Intake system leaks
Broken or leak in inlet duct from MAF sensor.
Loose clamps on inlet duct.
Sensor
Faulty or damaged PCM.
Signal shorted to ground or signal return.
Open ground between sensor and PCM.
Signal wire open circuit between sensor and PCM.
Open circuit on ground connection at sensor.
Open circut on VBATT connection at sensor.
===END OBDII DTC P0102-C===
===ICA DTC U0401:68-28===
Code: U0401 - Invalid Data Received From ECM/PCM
Additional Fault Symptom:
- Event Information
Status:
- Previously Set DTC - Not Present at Time of Request
Module: Smart City Brake Support
Freeze Frame :
-TOTAL_TIME: 126734352 sec - Total Time
-TOTAL_DIST: 103482.0 km - Total Distance
===END ICA DTC U0401:68-28===
===ICA DTC U0415:68-28===
Code: U0415 - Invalid Data Received From ABS Control Module
- Event Information
Status:
Freeze Frame :
===END ICA DTC U0415:68-28===
===ABS DTC U0401:00-2B===
Status:
Module: Anti-Lock Brake / Traction Control Module
Freeze Frame :
-IC_VPWR: 12.00 Volt - Instrument Cluster Power Supply
-AAT: 30 °C - Ambient Air Temperature
-PWR_MODE_KEY: Crank (Position 3) - Power Mode Key State
-APP_STATUS: Accelerator Pedal Off - Accelerator Pedal Position Status
-CFG_STATUS: Config Complete - Configuration Status
-ECT_STATUS: 0 - Under 80 degrees C - Engine Coolant Temperature Status
-RPM_STATUS: Under 1500 rpm - Engine RPM Status
-SHIFT_STATUS: P/N - Shift Position Status
-VSPD_STATUS: Stop - Vehicle Speed Status
-IG-ON_TIMER: 2 sec - Times Since Ignition Switch ON
===END ABS DTC U0401:00-2B===
===RCM DTC None===
Successful DTC reading, no error codes found
Module: Restraint Control Module
===END RCM DTC None===
===AFS DTC None===
Module: Adaptive Front Steering
===END AFS DTC None===
===SSU DTC None===
Module: Start Stop Unit
===END SSU DTC None===
===EPS DTC None===
Module: Electronic-Controlled Power Steering
===END EPS DTC None===
===F_BCM DTC None===
Module: Front Body Control Module
===END F_BCM DTC None===
===IC DTC U0433:68-48===
Code: U0433 - Invalid Data Received From Cruise Control Front Distance Range Sensor
- Event Information
Status:
- Test not complete
Module: Instrument Cluster
Freeze Frame :
-TOTAL_TIME: 126722768 sec - Total Time
-IC_VPWR: 10.50 Volt - Instrument Cluster Power Supply
-AAT: 27 °C - Ambient Air Temperature
-PWR_MODE_KEY: Running (Position 2) - Power Mode Key State
-IG-ON_TIMER: 4 sec - Times Since Ignition Switch ON
===END IC DTC U0433:68-48===
===IC DTC B11D4:53-48===
Code: B11D4 - Low Speed Collision Mitigation by Braking Disabled
- Deactivated
Status:
- Test not complete
Freeze Frame :
-TOTAL_TIME: 126740288 sec - Total Time
-IC_VPWR: 12.25 Volt - Instrument Cluster Power Supply
-AAT: 31 °C - Ambient Air Temperature
-IG-ON_TIMER: 27 sec - Times Since Ignition Switch ON
===END IC DTC B11D4:53-48===
disconnected
Status:
Freeze Frame :
Status:
Freeze Frame :
Status:
Freeze Frame :
Status:
Sensor
Improper connection
Intake system leaks
Sensor
- Event Information
Status:
Freeze Frame :
- Event Information
Status:
Freeze Frame :
Status:
Freeze Frame :
===RCM DTC None===
===AFS DTC None===
===SSU DTC None===
===EPS DTC None===
- Event Information
Status:
- Test not complete
Freeze Frame :
- Deactivated
Status:
- Test not complete
Freeze Frame :
P0102 is MAF, Make sure your airfilter is clean & the lid is properly fitted, give the MAF a clean with MAF cleaner.
B11D4 is one of the Sensors in the windscreen.
I have seen a Few MAF sensors play up in CX-5s.
U0415 Code in 2014 CX-5
About 2 weeks later they said they believed there was a grounding issue caused by a grounding point being painted over in a previous body repair. They cleaned this up and the problem occurred once again (at their shop).
They then said that they had determined the issue was a KD316788ZB, a CONTROL MODULE. POWER STEERING ASSIST MOTOR. I got the part and they replaced it (very expensive). In asking how they figured this out they said it was an ODBC Code U0415 that led them to this. When I look up this code it doesn't seem related, but I honestly don't know what all the KD316788ZB does.
My big concern is that we have the problem identified and fixed. If the issue is not the KD316788ZB, I would like to sell the part I replaced to try to recover some of the financial loss.
Since this user's post showed similar symptoms and since you seemed to have solved this issue and had some knowledge of these codes I thought I'd reach out.
Let me know your thoughts.
Hey drflanders what ever came of the u0442 code and remaining codes besides mass airflow sensor? Im having the same problem with a 2014 mazda 6, 2.5 liter. It has a p0102 also for MAF but main concern is communication code from PCM which has already been replaced and flashed by dealer. Thanks
