-   Mazda CX-5 (https://www.mazdaforum.com/forum/mazda-cx-5-54/)
-   -   Floor Mat Anchors (https://www.mazdaforum.com/forum/mazda-cx-5-54/floor-mat-anchors-31464/)
Old Doc Apr 22, 2013 09:01 PM
Floor Mat Anchors
Just picked up new CX 5 today . Can't figure out floor mat anchors . One of the plastic retaining circles was loose so tried to push it on the post with rubber mat in place . Couldn't get it to snap, so tried messing with it without the mat over the post . It snapped onto post but now I can't get it off the post nor can I release other rings that are holding the mat in place . What's the secret ? Owners manual by the way, just shows the post sticking through hole in the mat . Nothing about snaps .
Old Doc Apr 23, 2013 03:08 PM
Never mind. Figured it out.
CoSCX-5 Apr 26, 2013 07:47 AM
Well please share because I have already broken one of the clips trying to remove my mats.
paris1 Apr 26, 2013 08:07 PM
Most people are using a large flat-blade screwdriver to push down on the post while pushing up on the mat from underneath. It's not a great set-up, buy you can be sure your mat will never end up bunched up under the accelerator pedal a-la Toyota!:)
Old Doc Apr 27, 2013 06:32 AM
The arrangement seems unnecessarily complicated . All you need is a hook on the floor and a hole in the mat to go over the hook . In fact, that is what is shown in the owner's manual . I guess the lawyers got to them after the catalog was printed. My problem was that I had one of these clips loose and could not get the other one free to see how it worked .The plastic snap is two piece. One piece is on top of the hole in the mat and the other below it sort of like a sandwich . That then snaps onto the post . In my case , the top piece was lying loose in the floor and the bottom piece was snapped onto the post . It was not until I got the other one free using the above mentioned screwdriver method and could see how it worked , that I got it fixed . By the way , I do not recommend the $80 all weather mats . They are made of a black rubber that scuffs if you look at it . Don't know how I am going to clean them . It needs to be made of a slicker compound as are most mats .
UseYourNoggin Apr 27, 2013 08:21 AM
Which ones? Ones from Mazda?
I love mine, mine are aftermarket.
Old Doc Apr 27, 2013 05:40 PM
Factory All Weather mats in black .
Reggaetrix Apr 27, 2013 09:56 PM
I twist the mats at the anchor then lift and that seems to works for me
Old Doc Apr 28, 2013 09:40 AM
Not sure what you mean . When you say "twist" do you mean lifting mat up at the corner or turning it in a horizontal fashion . Hard to do the latter when it is anchored in place at two points .
Reggaetrix Apr 29, 2013 02:30 PM
it's sort of placing my thumb on the center of the ring and anchor, then grabbing the side closest to my thumb with my other fingers and bending the mat upwards towards the thumb. Kind of like in a bottle opener fashsion with my thumb as the pivot. That's what I found works for me.
