8 Attachment(s)
Air mix actuator might be broken, but still under your Warranty, -see below.
CX-5 Service & Repair Manual[size=13px] / [/size]HVAC[size=13px] / [/size]A/C[size=13px] / Air Mix Actuator Inspection [Full Auto Air Conditioner][/size]
CAUTION:- If the lever position exceeds the operation range shown in the figure, the circuit in the actuator could be damaged. Always perform an actuator operation inspection with the lever movement within the range shown in the figure.
Driver-side
1. Connect battery positive voltage to air mix actuator terminal C (or B), connect terminal B (or C) to ground, and then verify that the air mix actuator operates as shown in the table. - If the operation condition is not normal, replace the air mix actuator.
Attachment 7957
Terminal
Air mix actuator operation
B
C
B+
Ground
COLD > HOT
Ground
B+
HOT > COLD
2. Verify that the resistance between terminals F and G, E and F matches the air mix actuator operation as shown in the graph.
Attachment 7958- If the operation condition and resistance are not normal, replace the air mix actuator.
Passenger-side
Attachment 7959
Terminal
B
C
B+
Ground
HOT > COLD
Ground
B+
COLD > HOT
Attachment 7960
